PTO Shaft Removal 3011
harald
harald
I have to change the sliding gear on the front of the PTO shaft, the one thats connects to the gear from the engine.
I have dismantled the front gearbox cover, and the back cover over the bearings and the segring on the PTO at the end of the PTO.
Can I drag out the PTO or do I have to dismantel anything else it seems stuck.. Thanks for any Help
You can pull it out, but the rear end bering can stick so you need to give it a yank to losen that.
Thanks very much. do I have to replace the rear bearing afterwards ?
My 3011 is now in 2 peaces digging in to it..
undo the bearing cap at the shaft end at the back with four M12 bolts, then attach a PTO shaft coupler so you have something to pull on. There might be a Seeger ring at the back as well, cant remember.
Here are the parts that I have to replace to make my PTO work again Looking around for them.
http://www.flickr.com/photos/50597480@N04/
ask Lukas at www.ibeno.cz they have new parts at good prices
I have but they dont have the hollow shaft, its out of production
where do you live ?
in holland, try www.rietmanhasselt.nl they have a barn full of breakers.
Thanks for the tip. I live in Norway.. I have sent a mail to the company in Holland
We can source the parts you require www.zetor-dealer.co.uk
