question Hydraulic rakes on zetor 3320
Do you speak from a hydraulic powered hay rake or PTO powered one with hydraulic?
PTO powered shhould be no problem and hydraulic powered ... the question is than his oil consumption in L/min.
The connection may be different between them, but does it look like this ?
The Flip-Lever should control the oil flow speed.
This have nothing to do with the external hydraulic connectors. ;)
That works only for the internal hydraulic for the rear lift arms.
The flip-lever is called reaction speed lever and that means the oil flow setting for your lift arms.
Thanks for letting me know about the lever. I've only had the tractor for about 6 months not much info on them.
Somewhere on this forum, I believe there is a PDF Zetor Manual_96 where you may be able download.
May be here: FAQ - Manuals for Zetor tractors - https://zetorworld.com/threads/manuals-for-zetor-tractors.5393/
I may have gotten the manual here:
