question A little help with Zetor 6711
Drewskie
Wales
Andrew
Zetor 6711
Hi Everyone,
I'm New to tractors and picked up this 6711 last night. Overall its pretty tidy, everything works, she just needs a bit of tlc.
Would anyone know if theirs a return port for hydraulics? A bolt or plug that can be taken out maybe and adapted?
Any information on plumbing a return hydraulic feed would be appreciated,
Drew
Hello Andrew,
do you have one or two external hydraulic ports mounted?
every Zetor have a double working hydraulic valve, but not all have mounted both pipes for. A Picture from behind the tractor can help .
It has one external hydraulic port.
I have taken a few pictures of the back and underneath the seat
Here you can fit a second hydraulic pipe for e second hydraulic port:
Perfect! Thankyou.
So just to clarify that I'm safe to understand do the bolt and theirs nothing it's holding inside?
Appreciate you help ☺️
Just take a look at spare parts book:
hold the 39 and unscrew the 60... dont unscrew the 39 !!
then buy a new screw 8 and a new coper seal 10 and mount it with a new hydraulic pipe and hydraulic port as you need it.
Thanks, but no, it's not needed - just use our site/forum with posting some pictures from your Zetor and help also other Zetor fans if they need help. Thats enough. :)
