5718 cluch adjustment / Window rubber
richard_a
Richard A
HI must get round to adjusting cluch as it tears as I put it into gears, what is the correct setting for the travel release lever and the pto release lever inside the cluch????
Do I also need to do adjustments to the cluch tie rods ????
Broke top window glass , will try and get a new one cut locally, but the window rubber seal needs replacing, can I get rubber seal from anywhere or do I need zetor part????
Attempted to reply to the June post,but was locked out.
When I replaced the clutch, the fingers were set at 22 and 29 mm.
Main clutch worked fine, but pto does not release.properly
Found the following on an old posting, which recommended 21 and 33 mm.
Hope this will help you, I will be adjusting the pto clutch this week, and should be able to confirm settings.
Regards,
Matt
