I've never needed to use a PTO before, but now I want to use a ferti spreader. I gather that I have to select the appropriate PTO speed (540RPM) using the lever, and then run the engine at the corresponding revs as marked on the tacho.
All well and good, but the speed on the tacho is about 2,000RPM, which is somewhat faster than I normally run it; it sounds like it's revving its nuts off! Apparently I'm supposed to proceed at about 4mph. I want to do about 26 acres, so the engine will be operating at this speed for quite a while at that rate. I'm a bit concerned that I might have misunderstood and might blow the engine or something...
By the way, 2,000RPM seems likely to give more than 4mph even in 1st gear. Is it normal to use the low transfer ratio when doing this sort of thing? (Tractor is a Z7341, and the ferti spreader is a Vicon 400).
Thanks for any advice.
