I'm going to change the hydroulic pump on my beloved 8011, the service manual is not describing what exactly I can see on the Left side of the tractor. I can see a plate (around 6" by 6") with 4 bolts on the left rear axel. Is it where the pump located? I have received a brand new pump. Do I need anything else? I'm guessing I would need a sealing gasket!? I have gone through the forum and have read the steps to preserve the hydroulic oil. Any other tips would be great! I appreciate if someone take his/her time to help me answer my questions.
By the way, what about the hydroulic filter? Where is this one hiding? Please don't tel my that I need to split the tractor!!!
I have already cleaned and washed the reusable filter on the lest side of the tractor by simply opening a lid. Believe it or not, I found sands in it. Apparently the previous owner did not care about any derbies might fall inside when adding hydroulic oil in it!
Thank you indeed!
Thank you indeed!
