Zetor 6245 Hydraulic failure
decemberpoker
Dane
Hello, Im a newbie to the forum and would appreciate a little help. I have a 1986 model 6245 that appears to have complete hydraulic failure. I was using last week and started to lose power in the loader. Within 5 - 10 minutes no hydraulics worked. The brakes, front bucket, and rear arms will not work at all. I have checked the fluid level and it is right between the two marks on the dipstick. I also do not see any major. Does anyone have any suggestions. Hopefully this is something that I can handly myself. Thanks
I hate to sound dumb, but I just inherited the tractor. How do I check these two things?
You could try dropping the pump plate out of the bottom of the rear axle and see if the relief valve has blown apart or the suction filter is totally clogged.
