On top of the rear axle is a slotted vent plate, underneath you find a rod sticking up under 45 degrees, if you release the counternut you can adjust the parking band brake.
It might be easier to undo the M8 bolts of the cab floor and move it out of the way by stuffing a firewood log between the cab floor and 3pt hitch cover so you can work freely. Do not forget to take of the 3pt, remote hydraulics and P-M-D lever knobs off before you attempt...
i have checked into the adjusting nuts left and right. i have come across the rear plate left side 4 bolts and the pin that holds tensioner rod with spring has dislodged . The bracket that hold this into place does not appear to be going back on at all
What exactly did you take apart ? the bracket on the back, the S shaped thing on which this rod acts ??
If you open it by pulling the portal, i'd just go ahead and replace everything: brake shoes seals and band brake, and clean out the silt in the bottom of the housing too.
