7245 advice
robertjohnson
Robert Johnson
Had problems with the tractor starting.
Tip when changing the fuel filter use a small spring at the bottom to allow freeer fuel filter. Change the gauze in the glass cylider, the fuel returns to the atnk as not under pressure, I have fixed a small non return valve off a fulwood parlor to this and it has worked a treat. fitted by fuel pump.
Rob
Sounds interesting Robert. Can you explain:
1. "use a small spring at the bottom to allow freeer fuel filter"
2. " small non return valve off a fulwood parlor"
Basicly my dad is an expert in fullwood parlours and he keeps all his parts at home here. I tried this small non return valve, readilly available fitted it imbetween fuel line before glass cylinder. This stops the fuel returning to the tank. The fuel filter should on this tractor I believe have a small spring in the bottom of the filter ir then is free, helps fuel suply when starting. Only a small one 3-4 rings max 1/2 inch. Our Zetor is 96 m reg only one fuel filter.
Rob
