7045 fuel pump bleed screw
doberstaffie
doberstaffie
I have just changed the perished fuel pipes on my 7045, I started bleeding the system and got the bleed screw above the fuel filters ok, but I cannot see a bleed screw on the fuel pump? Does it have one or do i go straight to bleeding the injector pipes?
thanks!
usually bleeding the filters is enough. The fuel pump has one way valves which usually get rid of air within a few strokes.
