5245 clutch probs
scotiadave
ECoastDave
not very mechanical. clutch needs to be pumped several times to allow shift. is my problem simply gear/hydraulic oil low? it's a 1990 and has worked excellent for me the past 4 yrs.
Try topping up the brake fluid, the clutch reservoir is in the centre of the brake fluid tank. then bleed through if the problem persists. Then clean and check for leaks on the Master cylinder and the slave cyl. hope this helps, Dave
