Topic Messages
Zetorworld forum
Tractor forum
clutch for Zetor 5211
Moderators: Renze, TomZ
The Web Zetorworld.com only
Stephanie
Guest
  Started at Tue Apr 12 03:11:13 2005
I need a new clutch to my Zetor 5211 tractor. My PTO is not running properly. Gears are always grinding. How much does it cost to get a new clutch? Where do I find parts? What all do I need to get someone to fix it? HELP!!!!!!!!!!! Just bought a farm and the tractor came with it for a small fee. But the fee seems to be getting BIGGER.
Thank you,Stephanie
  E-mailE-mail
Arctic003
Gender:
Re: clutch for Zetor 5211
  Reply #1 Posted at Tue Apr 12 04:52:31 2005
Firstly DONT PANIC! It might not be so bad wink
Can you explain the problem with the PTO more?
Also, remember that tractors don't always have synchromesh gearboxes (like cars do). At least, my Zetor 6945 has a non-synchromesh gearbox, and I suspect that yours is the same.
In this case some crunching and grinding is normal, unless you double-declutch.
If I'm doing field work, I usually just set off in the gear that I'm going to need. If I'm transporting something on the road, I'll need to change gear but only between fourth and fifth.
Technical details of double-declutching later if you need; I have to dash now, horses to feed...
J-P
Renze
Administrator
Member Icon
Goed goan !!
Gender:
  Reply #2 Posted at Tue Apr 12 15:54:14 2005
What clutch do you use for the PTO ?? Did you know that the lever next to the hand brake is the PTO clutch ??
Next, you might want to adjust the bowden cable of the clutch PTO before splitting the tractor
Big Orn
Gender:
  Reply #3 Posted at Tue Jun 7 15:12:23 2005
Last Modified at Tue Jun 7 15:13:19 2005 by Big Orn
On Tue Apr 12 03:11:13 2005, Stephanie wrote: (read quoted post)
Thank you,Stephanie
I'll echo Renze, Stephanie - the lever on your left side, the one nearest you, (as you're sitting in the seat) is the clutch lever for the PTO. You must have it pulled up enough to disengage, then shift the left lever at your feet into gear, and slowly lower the lever back down.
On another note - there is a fluid spout underneath the floorboard that supplies lubrication to the main clutch. If the tractor has been sitting for awhile, you need to add some fluid. A medium-sized syringe will help.
Let us know...
From Texas, USA --- 2006 Zetor 6341 Super with Loader.
Orange
  Reply #4 Posted at Thu Jun 9 19:31:50 2005
Stephanie,
Where are you from?
Member List Member List
Who's online: 12 guests
